Ext. Flash drivers for M5282EVB
3,384 次查看
TTA
I am in the process of purchasing the M5282EVB Evaluation Board for the MCF5282 microprocessor.
Do i get  the Flash drivers to write to the External Flash? If so , where can i find it?
Please let me know.
Thanks.
TTA
标签 (1)
标记 (1)
2 回复数
1,744 次查看
TTA
Thanks. The M5282EVBUM.pdf gives the information that the flash device is Am29lvl60DB and also to "Refer to the specific device data sheet and sample software provided for configuring the flash memory". Is the software same as the flash driver or is it something else. If its not, will i get some application notes or some documentation that i can use to write to the flash device?
TTA
1,744 次查看
Technoman64
