DAP in TWR-LS1021
DAP in TWR-LS1021
1,378 次查看
ninesun
How can I use dap in TWR-LS1021 board ?there are two question abou it:
1.How about the firmware for DAP in TWR-LS1021 board,Can I use the standard firmware for the CMSIS DAP ?
2. As I know. the ccs application in Code warrior can use the code warrior tap to connect with LS1021. Can ccs support the DAP to connect with LS1021?
1,336 次查看
yipingwang
1. You can use the standard firmware for the CMSIS DAP.
2. CCS supports the DAP to connect with LS1021.
