CodeWarrior USB TAP problem
DanRobinson
MPC5125 tower kit
CW USB TAP
Win7
CW MobileGT 9.2
CW debugger data drop v9.2 build 5125 sp 830
CW build 090311, mpc5125 service pack 1
JTAG config file C:\Program Files\Freescale\CodeWarrior for MobileGT V9.2\USB_TAP_JTAG.txt
target init file {Compiler}PowerPC_EABI_Support\Initialization_Files\52xx\5125ADS_init.cfg
I have CodeWarrior 9.2 Mobile GT installed on a Win7 machine.  When I used the Tools -> Hardware Diagnostics to try to try to write to memory, I get an error "JTAG chain does not contain any debuggable cores".  I have set CW to run as Adminstrator.  'Before I did that, I got an error that I needed to check my JTAG clock speed.
Here is the protocol log
CCS: 0000 : ccs_open
CCS: : ipaddr = 127.0.0.1
CCS: : port = 41475
CCS: : timeout = 10
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 10
CCS: : Error message:
Connection refused
CCS: : port = 41475
CCS: : timeout = 10
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 0
CCS: 0000 : ccs_get_connection_count
CCS: : serverh = 0
CCS: : count = 1
CCS: : ccs_get_connection_count; ccs_error = 0
CCS: 0000 : ccs_available_connections
CCS: : serverh = 0
CCS: : count = 1
CCS: : ccs_available_connections; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_delete_cc
CCS: : serverh = 0
CCS: : count = 0
CCS: : ccs_delete_cc; ccs_error = 0
CCS: 0000 : ccs_config_cc
CCS: : serverh = 0
CCS: : config_string = utap:0
CCS: : ccs_config_cc; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_set_timeout
CCS: : serverh = 0
CCS: : timeout = 10
CCS: : ccs_set_timeout; ccs_error = 0
CCS: 0000 : ccs_kill_server
CCS: : serverh = 0
CCS: : ccs_kill_server; ccs_error = 0
Anyone using USB TAP on win7?
DanRobinson
I have also applied the fix from AN4338.  The driver is LibUSB-win32.
