CodeWarrior - Pin Muxing Configuration LS1043A
juergene
Hello Community,
i have a question about the Pin Muxing Configuration (CodeWarrior) for the LS1043A.
The LS1043A has 2 different pin assignments, one is 21x21 (621 ball layout) and the other one is 23x23 (780 ball layout).
When i try to configure the LS1043A i only got the LS1043A with 21x21 (621 ball layout). Is it possible to change this to 23x23 (780 ball layout)?
I use the following CodeWarrior Version:
Thank you very much.
Juergen
addiyi
Unfortunately in this moment this option is not available.
Adrian
