trying to make a program using C
Santanafx
Hi everyone, im trying to make the same program from assembly to C
By the way im using the microcontroler MC68HC908QY4
My program in assembly is this.
DELAY: DS 1
MyCode:     SECTION
main:
_Startup:
CONFIGURATIONS:
                  LDA  #$19
                  STA CONFIG1 ;no COP; no LVI; +5V
                  LDA #0
                  STA CONFIG2   ;3,2MHZ ; no extern interruption; no RESET;
                  LDA #$38
                  STA DDRA    ;PTA5 , PTA4 E PTA3 outputs
INI:
GREEN:
              LDA #$20
              STA PTA   ;turn on
              BSR D1SEC
YELLOW:
                    LDA #$10
                    STA PTA   ; turn on
                     BSR D1SEC
RED:
                        LDA #$08
                        STA PTA  ;turn on
                         BSR D1SEC
                        BRA INI
D1SEC:
              LDA #100
              STA DELAY
D10MILI:
                LDX #100
D100MICRO:
                      LDA #80
 LOOP:
              DECA
              BNE LOOP
                DECX
                BNE D100MICRO
                DEC DELAY
                BNE D10MILI
              RTS
              END
This program uses three LEDs when choosing each output (PTA3, PTA4, PTA5), the LED is turned on, for one second, the loop D1SEC, creates a delay of 1 second.
Here is the same program but with two loops now, each loop will make the leds be turned on with diferent times. There are some minor changes now, but the program as i said is the same. The program with assembly is working fine!
            INCLUDE 'derivative.inc'
            XDEF _Startup, main
MY_ZEROPAGE: SECTION  SHORT
TIMESIGNAL: DS 1
DELAY: DS 2
MyCode:     SECTION
main:
_Startup:
CONFIGURATIONS:
                  MOV #$19, CONFIG1
                  MOV #0, CONFIG2
                  MOV #$38, DDRA
                  MOV #$1, PTAPUE
INI:
READKEY:
          LDA PTA ;A=X X GREEN   YELLOW   RED   X X CH0
          AND #1; #1=0 0        0              0              0      0 0   1
          BNE  TEMP1 ;A=0000000CH0
TEMP0:
GREEN:
              MOV #$20, PTA
              MOV #5,TIMESIGNAL ;5SEC
LGREEN:
              BSR D1SEG
              DEC TIMESIGNAL
              BNE LGREEN
YELLOW:
                    MOV #$10, PTA
                    MOV #2, TIMESIGNAL ;2SEC
LYELLOW:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LYELLOW
RED:
                        MOV #$08, PTA
                       MOV #4, TIMESIGNAL ;4SEC
LRED:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LRED
                        BRA INI
TEMP1:
GREEN1:
              MOV #$20, PTA
              MOV #4,TIMESIGNAL ;4SEC
LGREEN1:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LGREEN1
YELLOW1:
                    MOV #$10, PTA
                    MOV #1, TIMESIGNAL ;1SEC
LYELLOW1:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LYELLOW1
RED1:
                        MOV #$08, PTA
LRED1:
              BSR D1SEC
              DEC TIMESIGNAL
              BNE LRED1
                        BRA INI
D1SEC:
               MOV #100, DELAY+1
D10MILI:
                 MOV #100, DELAY
D100MICRO:
                      LDA #80
 LOOP:
              DECA
              BNE LOOP
                DEC DELAY
                BNE D100MICRO
                DEC DELAY+1
                BNE D10MILI
              RTS
              END
And now here is my problem, when im trying to make the same code (using the code with 2 loops), it gives me an error in line 19)
#include <hidef.h> /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
#define RED 0x08
#define GREEN 0x20
#define YELLOW 0x10
#define DLY5 40000
#define DLY2 16000
#define DLY4 32000
#define DLY1 8000
void temporiza( unsigned long int);
void main(void)
  CONFIG1=0x19;
  CONFIG2=0x00;
  DDRA=0x38;
  PTAPUE=0x01;
if(!PTA_ PTA0)                          // MY PROBLEM IS IN THIS LINE
for( ;; )
PTA=GREEN;
temporiza(DLY5);
PTA=YELLOW;
temporiza(DLY2);
PTA=RED;
temporiza(DLY4);
else
PTA=GREEN;
temporiza(DLY4);
PTA=YELLOW;
temporiza(DLY1);
PTA=RED;
temporiza(DLY2);
void temporiza( unsigned long int delay)
while(delay--);
Im trying to make my if works.
Someone can help me please?
Thanks a lot for your time.
bigmac
Specialist III
Hello, and welcome to the forum.
Firstly, you have some major structural problems with main() function.
void main(void){   CONFIG1 = 0x19;   CONFIG2 = 0x00;   DDRA    = 0x38;   PTAPUE  = 0x01;}   if (!PTA_ PTA0) {      // MY PROBLEM IS IN THIS LINE   for ( ; ; ) {            PTA = GREEN;      temporiza( DLY5);      PTA = YELLOW;      temporiza( DLY2);      PTA = RED;      temporiza( DLY4);   }   else {      PTA=GREEN;      temporiza( DLY4);      PTA=YELLOW;      temporiza( DLY1);      PTA=RED;      temporiza( DLY2);   }}
The function exits immediately after the initialisation.  The main() function must never exit.  The remainder of the code is dead.
Had the function not exited, you would have been entering an infinite loop if the input pin was active high - not what you intended.
Had you created the project using the new project wizard, these problems would not have occurred because a framework is created for main(), to assist in obtaining lthe correct format.  Your code might also take into accout that the project might eventually use interrupts, and that the COP timer would be active.  The framework code also takes this into account.
Here is the corrected version of your code.
void main(void){   CONFIG1 = 0x19;   CONFIG2 = 0x00;   DDRA    = 0x38;   PTAPUE  = 0x01;   for ( ; ; ) {      // Main loop            if (!PTA_ PTA0) {         PTA = GREEN;         temporiza( DLY5);         PTA = YELLOW;         temporiza( DLY2);         PTA = RED;         temporiza( DLY4);      }      else {         PTA = GREEN;         temporiza( DLY4);         PTA = YELLOW;         temporiza( DLY1);         PTA = RED;         temporiza( DLY2);      }   }}
With such long delays generated by the delay function, the COP timer should be periodically cleared within the delay loop, to allow for occasions when the COP timer is enabled.  This extra code will affect the calibration of lthe delay loop.
A far better way of generating long time delays is to make use of the TIM module and the TIM overflow interrupt.  Simply initialise a global counter variable to the delay required.  Then, within the TIM overflow interrupt function, test the counter value for non-zero, and if so decrement the counter.
if (TIMcount)  TIMcount--;
When the counter value reaches zero, the required delay has expired.
volatile unsigned int TIMcount;  // Global variable// Delay by multiple of TIM overflow periodvoid delay( unsigned int val){   TIMcount = val;   while (TIMcount)  __RESET_WATCHDOG();}
Mac
Santanafx
Thanks a lot for your help bigmac, it worked fine now!!! Such a terrible mistake... Anyway thanks a lot!!!
I have another simple question, i have to make this same program with 4 diferent loops. In assembly i manage to make this doing a minor change, the program now uses
_Startup:CONFIGURATIONS:                                    MOV #$19, CONFIG1                   MOV #0, CONFIG2                       MOV #$38, DDRA                     MOV #$3, PTAPUE INI:LERCHAVE:          LDA PTA ;A=  X   X    GREEN     YELLOW           RED         X    CH1  CH0          AND #3; #1=  0   0       0       0                 0        0    1      1          BEQ  TEMP0 ;A=000000CH1CH0   CH1CH0=00          DECA          BEQ TEMP1          DECA          BEQ TEMP2TEMP3:                      MOV #$20, PTA                          BRA INITEMP2:                      MOV #$10, PTA                      BSR D1SEC                      MOV #0,PTA                      BSR D1SEC                      BRA INI
TEMP0,TEMP1,PISCAAMARELO,FIXAVERDE. Are my diferents loops. The program above dont have the loops, TEMP0 and TEMP1, they are the same as before.
How can i manage to do this in C?
Thanks a lot
bigmac
Specialist III
The simplest way of handling more than two input states would be to use a switch statement ...
#define OFF  0x00...void main( void){   ...   for ( ; ; ) {             // Main loop            switch (PTA & 0x03) {  // Input range 0-3      case 0:         PTA = GREEN;         temporiza( DLY5);         PTA = YELLOW;         temporiza( DLY2);         PTA = RED;         temporiza( DLY4);         break;      case 1:         PTA = GREEN;         temporiza( DLY4);         PTA = YELLOW;         temporiza( DLY1);         PTA = RED;         temporiza( DLY2);         break;      case 2:         PTA = YELLOW;         temporiza( DLY1);         PTA = OFF;         temporiza( DLY1);         break;      default:   // case 3:         PTA = GREEN;      }   }}
Mac
