compiler setting (callee not defined, compiler no error)
1,042 次查看
leslieyang0509
Codewarrior 10.3
When caller call a callee, the callee was not defined, the compiler result does not generate error.
How to change compiler setting to when callee was not defined, the compiler will generate error.
Example:
int main()
  foo();
the compiler will not generate error message.
Leslie
标记 (3)
805 次查看
CrasyCat
Specialist III
Hello
  Go to the ARM Compiler > Language page and check the Require Function Prototypes edit box.
CrasyCat
4 回复数
805 次查看
CrasyCat
Specialist III
Hello
Which MCU are you targeting (HCS08, ColdFire, Kinetis, ...)?
CrasyCat
805 次查看
leslieyang0509
Dear Catherine,
NK60DN512
100MHz
mask 2N22D
Here is the snapshot of settings.
Leslie
806 次查看
CrasyCat
Specialist III
Hello
CrasyCat
805 次查看
leslieyang0509
Dear Catherine,
it works!
Thank you.
Leslie
