Upgrade processor expert
2,196件の閲覧回数
grzegorzK
Dear
How to upgrade "processor expert" for Codewarrior IDE 5.9.0.
I do not see any patches for this version, only for version 5.1.
Definitely I do not have the newest version of PE because from header of generated C file I found "db: 3.00.016" since my colleague using "db: 3.00.033". But no one know how to upgrade it.
/G.K.
タグ(1)
1,981件の閲覧回数
grzegorzK
Ad. CPU: Yes, I am sure.
I found problem, I have version 5.0 of CW while others 5.1. And seems there is no option to upgrade. Am I right?
3 返答(返信)
1,981件の閲覧回数
ProcessorExpert
Senior Contributor III
are you sure that you have selected the same CPU as you colleague and both have installed the same version of Processor Expert?
Fresh CW V5.1 is delivered with Processor Expert V3.02.
You can find the version of Processor Expert in readme.txt or in About dialog box window.
best regards
Vojtech Filip
Processor Expert Support Team
1,982件の閲覧回数
grzegorzK
1,981件の閲覧回数
ProcessorExpert
yes, you are right. There is no option upgrade.
best regards
Vojtech Filip
