Tab names
2,477件の閲覧回数
rlw
I am using SlickEdit Version 15.0.1.3 with the latest hot fixes.
Something I have noticed for a long time, the documentation says that tabs for files with same name but different extension would show only only tab with the full name and the rest with just the extension.
While this works for source code, such as .c and .h, files, it does not appear to work for non-source code files, like .mak and .prm.
I have attached a screen picture to show this.
タグ(1)
2,160件の閲覧回数
CrasyCat
Specialist III
Hello
Are you sure you are targeting the appropriate forum here?
This forum can help you with questions related to CodeWarrior tool chain.
Slickedit is not a Freescale product. I assume you install a SlickEdit plug in on top of your CodeWarrior installation.
Please check on http://www.slickedit.com/products/slickedit-core. There is a dedicated forum up there.
CrasyCat
2,161件の閲覧回数
CrasyCat
Specialist III
Hello
CrasyCat
