String Search in IDE 5.7.0 Build 1932 causes crash
已解决
跳至解决方案
3,061 次查看
CaffineCoder
hi guys has anyone else found that doing a string search (ctrl+shift+M) crashs the IDE almost everytime?
this causes an enormous amount of rage :smileymad: as the project i am working on has alot of files and it is helpful to scan thru like this ?
i have updated but the problem still persists any ideas out there .... percussion maintenance is the next step for me
Message Edited by CaffineCoder on 2006-09-2706:38 PM
标签 (1)
标记 (1)
1 解答
2,069 次查看
CrasyCat
Specialist III
Hello
As far as I know there should be a CodeWarrior FAQ around that.
Basically there is an easy way to avoid the crash.
 - Close the IDE
 - Extract the content of the attached .zip file to your "{Install}\bin\Plugins\Support\Products" directory.
 - Restart IDE.
Crash should not happen any more.
CrasyCat
在原帖中查看解决方案
2 回复数
2,069 次查看
CaffineCoder
:smileyvery-happy: JOY it works a treat thanks alot
2,070 次查看
CrasyCat
Specialist III
Hello
 - Close the IDE
 - Restart IDE.
CrasyCat
