OSBDM and ICG trim
OSBDM and ICG trim
3,229 次查看
peg
Senior Contributor IV
When using the Open Source BDM, how are you meant to calculate and then programme the non volatile version of the ICG trim value?
BR Peg
标签 (1)
标记 (1)
1 回复
1,200 次查看
peg
OK,
I figured out I can write a small cmd file to write the value to FLASH using the FCMD register. Now to calculate the value....
Well I can calculate the value required too with technique from AN2496 but this hardly compares to the ease of use with P&E's BDM.
How do they do it? or is there already a way within Hiwave?
BR Peg
Message Edited by peg on 04-16-200610:51 PM
