MM9Z1_638 In-chip temperature sensor how to get environment temperature
1,583 次查看
Jeffrey_Xie
I'm use MM9Z1_638 with its In-chip temperature sensor to get environment temperature;
But,due to the self-heating effect, the temperature read will slowly rise;In the first 100S,temperature is rise quickly,close to 5℃;And,close to 300S,temperature again rise 1 ℃,close to 900S,again rise 1 ℃;
Could you please tell me how to compensate the error caused by the self-heating effect
1,572 次查看
TomasVaverka
Please take a closer look at the AN12301 describing calibration processes of the MM9Z1 temperature sensor.
Tomas
