Install Code Warrior Error
2,277 次查看
zhaoqinsu
When I installed Code Warrior 8.7 ,there is a problem just as in the picture .Now I am very anxious to use this software.
Some one can help me ?Thank you very much !
2 回复数
1,970 次查看
martin_kovar
from the figure you posted above it looks like you use Windows 7. Unfortunately, Code Warrior 8.7 is supported only until Windows XP and most probably it will not be possible to install this product into this operating system.
About the security notice, it looks like the driver you try to install in not subscribed by any known certification authority (or operating system cannot verify the signature.)
Martin
1,970 次查看
zhaoqinsu
Codewarrior wroks well now , but I can't open the project copied from another guy ,as that in the picture ; picture2.png
