Import file with CW without overwrite existing source
joelesco
I'm always using the Import -> File systeme to add in my project part of file from other project ! But this method don't make a copy and overwrite the existing source when I change something on it !
What is the best way to do the same ?
thanks a lot !!!!!
ZhangJennie
i just tried import feature i didn't see any problem.
can you post your step by step screenshot so that we can see how the problem was happened?
joelesco
Sorry, I don't know what i did but the problem is finish.
Thanks Zhang !
