How to auto generate code using vector tools during compilation via Code Warrior
9,033件の閲覧回数
krishnakarthik6
Hi NXP,
Currently I am working on Battery Management Project and am using MM9Z1638 controller CodeWarrior 10.6 as  IDE. Currently we use vector tool Geny to generate the LIN stack. So please let me know if there is a possibility of generating the code (stack) and getting compiled (Code warrior 10.6) when I change the configuration in the Geny and build the project.
Thanks & regards,
Krishna Karthik
4 返答(返信)
8,207件の閲覧回数
ZhangJennie
Hi Krishna,
From my understanding, you want to use GENy tool generate code, and use these code under CW10.6. correct?
GENy is product of vector Vector: Software + Services for Automotive Engineering
actually we don't have much experience on it.
I may suggest you contact Vector Vector: Software + Services for Automotive Engineering  to query if GENy generated code can support NXP CodeWarrior.
if don't directly support, user has to modify it self. Because as we know, we don't have tool to do this conversion.
Jennie Zhang
8,207件の閲覧回数
krishnakarthik6
Hello Zhang,
I am able to generate the code using Geny and path for generated files is pointed to the project directory. I am able to build the project successfully after generation. But currently I am doing this process manually, so my question is there a way we can automate the files generation process while building ?
8,208件の閲覧回数
sakthivelkuland
I am also looking for the same Geny Generation process for S32K144 MCU Family with S32 Design Studio.
I want to generate CAN Stack using GENy Configuration Tool.
Please let me know how you have done the process Successfully?
share if any guideline documents you have.
Sakthivel K
8,208件の閲覧回数
ZhangJennie
Hi Krishna,
Unfortunately, we don't have an automated tool that can do this conversion.
Jennie Zhang
