How and where to program and compile  an eMIOS and dump it to MPC5676R?
605件の閲覧回数
snehakalkhair
タグ(1)
491件の閲覧回数
martin_kovar
for compile eMIOS code you can use for example:
CodeWarrior Dev Tools for MPC55xx/MPC56xx|NXP
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
or
MULTI Integrated Development Environment
For flash the code could be used debug probes or standalone flashers.
With CodeWarrior could be used these debug probes:
Universal Multilink Development Interface|NXP
Universal Multilink FX High-Speed Development Inter|NXP
With MULTI IDE could be used
Multi-core JTAG, EJTAG, COP, BDM hardware assisted debugger, embeddeddebugging, on-chip debugging - ...
Also Lauterbach is possible to use as a flasher and debugger
TRACE32® Qorivva MPC5xxx and SPC5xxx Debugger
And as a standalone flasher I can recommend you Cyclone MAX
Cyclone MAX|NXP
Martin
