Couldn't write flash driver to target
1,154 次查看
wangchengwei22
when I use my cw v10.1 to download a project to k60n512,it says: Error: Couldn't write flash driver to traget.Memory verify failed at location:0x20000000.Please make sure you are not trying to write to a read-only location.
I searched this problem in forums,someone said it is a hardware fail,the cause is reset bottom is connected to ground.But my board is bought from freescale.com,and I think it can't be a hardware problem.
but  how can I slove this problem.any solutions?
Thanks!
标记 (1)
0 回复数
