Codewarrior 10 compiler version?
ソリューションへジャンプ
3,107件の閲覧回数
irob
Contributor V
I'm required to state the compiler name and version in our company source code.  I've just upgraded to CW 10 and I'm having a hard time finding this.  Though during builds, I can see that Freescale migrated to GCC.
In the Help > About, I see a bunch of credits, but not specifically for the compiler.  The closest I can find is:
CodeWarrior HCS08 Debugger 10.1.0.FSL_b5490
Anyone else see the compiler?
タグ(1)
2,699件の閲覧回数
CrasyCat
Specialist III
Hello
Compiler version is not available in the About box.
In order to retrieve the compiler version number:
  - Open an Explorer window
  - Browse to {Install}\MCU\prog
  - Double click on chc08.exe
  - In the HC08 Compiler window select help > About and you should see the compiler version number.
CrasyCat
2 返答(返信)
2,700件の閲覧回数
CrasyCat
Specialist III
Hello
CrasyCat
2,699件の閲覧回数
irob
Contributor V
Perfect, thanks!  I never would have found that.
