CW6.1 change MCU
CW6.1 change MCU
Thetiger
This is regarding CDC terminal demo with DEMOJM60 board. My problem is that if you compile the demo as it is, it will
compile without any error but when you change the MCU to JM8 or JM16, it shows error. What can be the problem ? This is even if you change to the same MCU that is JM60. Can anybody help ? Thanks.
NavidadRedivivu
Can you please post the error here ?
