CW v10.1 EWL scanf files
2,372件の閲覧回数
julio_perez-arr
In this release of Code Warrior CW v10.1:
please, where are the "scanf" function files in the EWL library for Coldfire Support ?
5 返答(返信)
2,293件の閲覧回数
julio_perez-arr
Thank you Mike,
Is v10.7 the latest version of CW v10 ? Where can I find the release notes ? Where can I download from ?
What are the differences in v11.1 ? just to check compatibility and troubles.
2,293件の閲覧回数
Hui_Ma
I download and install latest CodeWarrior for MCU V11.1 IDE software, which also includes those files.
Please download the latest CodeWarrior for MCU V11.1 IDE software from here.
Related CodeWarrior for MCU V11.1 Release Notes, please check here.
Wish it helps.
Mike
2,293件の閲覧回数
Hui_Ma
There with below description at <CWMCUCFCMPREF> document:
The CodeWarrior project for ColdFire product with below auto EWL library configuration:
The related ColdFire Linker with below options:
" -m __startup -L"C:\nxp\CW MCU v10.7\eclipse\../MCU/ColdFire_Support/ewl/lib"
Wish it helps.
Mike
2,293件の閲覧回数
julio_perez-arr
Thank you for you response.
My question is: in the same way that "scanf" standard C library funcion files are defined for ARM Support:
where can I find the same files for Coldfire Support ?
I much appreciate your support,
KR
2,293件の閲覧回数
Hui_Ma
Hi KR,
I could find my installed CodeWarrior for MCU V10.7 with those files:
I would recommend to download and install the latest CodeWarrior for MCU V11.1 software.
Wish it helps.
Mike
