Hello All,
OK, all was going as well as can be expected with my project when something changed in my project settings because suddenly I started getting the C1005 errors on compile. I had used this specific piece of code in many, many projects and never had this issue before.
#define MAX_QUE_SIZE 48
typedef struct QUE
unsigned char buffer[MAX_QUE_SIZE];
unsigned char head;
unsigned char tail;
}que;
The last line "}que;" is where the error is being reported.
Looking at the very brief description of this error "A declaration contains an illegal storage class." in the documentation means somehow I used a keyword. I don't see it.
Anyone have any ideas what could have changed in my project settings to cause this error to occur? Any ideas on how to fix it?
Info:
Win 7
Codewarrior 10.3
HCS08 project (9S08AW60)
Dave
已解决! 转到解答。
Thanks the response but I just found the problem. It is related to a missing semicolon in a completely different .h file. I found this past posting here:
https://community.freescale.com/message/28495#28495
I started to poke around my different .h files and realized I added a new function and forgot the semicolon. Been doing this C thing for 15+ years and everytime I have one of these weird errors that costs me hours of time it always turns out to be caused by a simple missing character.
Hi Dave,
I would produce a preprocessor listing and inspect what the compiler is seeing. To create the preprocessor listing, right click on the source file in the editor and select that menu.
I suspect you have somewhere a macro set to something you use in your source/struct.
I hope this helps.
