Activate processor expert in CW V10.6
Jep
i program in assembler and use CW V10.3 I recently upgraded to V10.6. Unfortunately in this version you dont have access to PE unless you program in C or C++ but you do get a message that says there is a way to enable PE .
PLease see my other post called Processor Expert to see a screen capture of this message
Does any one know how to do this
Jorge_Gonzalez
Hello Jeff:
Just like my colleague Pascal mentioned, this is not possible.
As for the message, that was mistakenly left there. I know such message causes confusion, sorry about that, but the short answer is: there is no way to enable Processor Expert in an assembler project.
Workaround: Create a C project with PEx support and import all the files from your assembler project to this new project.
I hope this helps clarifying.
Regards!,
Jorge Gonzalez
