i've lost the ability to set breakpoints. when i attempt to set, i see the little icon indicating a breakpoint but it's got a slash across it and execution won't stop
768 次查看
danielfreepons
- CodeWarrior for MCU
     Version: 10.5
     Build Id:130916
i'm able to stop execution by clicking the 'pause' button
703 次查看
Carlos_Mendoza
Hi Daniel,
I think that the following post created by our colleague Erich Styger might be helpful for you, it explains the difference between software and hardware breakpoints and what to do when you run out of hardware breakpoints:
Software and Hardware Breakpoints | MCU on Eclipse
Hope it helps!
Carlos Mendoza
Technical Support Engineer
