how to migrate from codewarrior to DDC-I OpenArbor
4,026件の閲覧回数
dineshs
6 返答(返信)
3,856件の閲覧回数
dineshs
chip part number MPC5676RRM , I am working in DDC-I OpenArbor IDE  (6.6.4.r80932) .
3,856件の閲覧回数
martin_kovar
we do not have any tool for project migration from CodeWarrior to DDC-I OpenArbor IDE, even this IDE is not NXP product, so I am not able to tell you where is the problem.
From my point of view, the best way for you is to contact DDCI support directly. Please see following link:
Software Trouble Report (STR) – DDC-I
Martin
3,856件の閲覧回数
dineshs
after migration I am getting following errors
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .sbss lma 0x40009a18 adjusted to 0x4000ec18
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .bss lma 0x40009a2c adjusted to 0x4000ec2c
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .interp lma 0x4000ec18 adjusted to 0x400124d0
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .dynsym lma 0x4000ec2c adjusted to 0x400124e1
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .dynstr lma 0x4000ec2c adjusted to 0x400124e1
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .hash lma 0x4000ec3c adjusted to 0x400124ef
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section `.data' can't be allocated in segment 3
LOAD: .sbss .data .dynamic
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: The first section in the PT_DYNAMIC segment is not the .dynamic section
C:/DDC-I/usr/local/cross-compilers/gcc-4.6.1/bin/powerpc-motorola-elf-objcopy:D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5[.text]: Bad value
3,856件の閲覧回数
ZhangJennie
Please let us know what CodeWarrior version you work with and your chip part number. Thus we can contact the proper engineer to assist you.
Thanks.
Jennie
3,856件の閲覧回数
dineshs
chip part number MPC5676RRM , I am working in DDC-I OpenArbor IDE  (6.6.4.r80932) and  Code Warrior IDE version   5.9.0
3,856件の閲覧回数
ZhangJennie
Hi Dine,
What chip and what version of CW do you work with?
Jennie Zhang
