how to copy code from ROM to RAM and run it in MKL05z32 and cw10.6?
3,486 次查看
wangbaode
dear,
I want to copy code from ROM to RAM and run it in MKL05z32. my software is cw10.6.
please help me!
标签 (1)
标记 (4)
3 回复数
2,791 次查看
ZhangJennie
hello Ivan.
I suggest you check this document
Relocating Code and Data Using the CW GCC Linker File for Kinetis
it includes how to copy code from ROM to RAM
this answer is for you. if it helps, please click on "Correct Answer " button. thanks!
Best Regards.
Zhang Jun
2,792 次查看
drqubit
I think wang baode means copy. Not link the code in RAM space.
2,792 次查看
drqubit
Hello.
You can easily copy it using memcpy.
Take a look at this code snippet:
void romFunction (void)
     //Do your stuff
void main (void)
  uint8_t ramSpace[1000];
  memcpy (ramSpace,romFunction,1000); //Don't care if you copy more code than needed. After function return, no code will be executed
  void (*ramFunction)(void)=(void (*)(void))ramSpace;
  ramFunction();
Regards.
