getting error while programing and erasing nor flash in codewarrior 8.8
1,824件の閲覧回数
venkat1
hello folks,
1,758件の閲覧回数
yipingwang
Hello venkat d,
You need to customize CodeWarrior initialization file for your custom board based on the CW initialization for the demo board. In your console log, there is problem to read DDR memory, so the flash program algorithm cannot be executed in DDR memory.
 Please modify "DDR Controller Configuration" section in CodeWarrior initialization file for your custom board.
Please do Memory Read/Write  and Memory Tests from Tools->Hardware Diagnostics before doing flash programming.
Yiping
