code warrior tap driver problem
威杨
Hello ,
   I can use codewarrior usb,but i can't use codewarrior tap, my pc system is window7 32bit, the code warrior ide is 10.4.0, pc device manage is
could you give me some advises.
THANKS.
ZhangJennie
What chip do you work with?
What's your CW version?
What's your USB tap version?
Jennie Zhang
