chc08 compiler and WmsgNu command line option.
WHookway
I am compiling using chc08 5.0.39 Build 11346.  The CW HC(S)08 Build Tools Manual refers to the WmsgNu command line option to Disable user Messages.  However, when this is included on the command line I get the following
FATAL C50: Input File: 'WmsgNu=abe'  not found
The compile terminates with an "Error occurred while processing", is this a valid option for the chc08 compiler?
As the project is small I am using an unlicensed version of the compiler.
Any suggestions?
Thank You,
Will Hookway
Tags (2)
ZhangJennie
can you please post all the related screenshot and demo code for how to reproduce your problem? thansk!
