acceleromtre speed
acceleromtre speed
1,263件の閲覧回数
naifarmourad
hello , Can I use the acceleromtre to determine speed ??
What is the formula ?
1,221件の閲覧回数
ZhangJennie
Hi Naifar,
The acceleration is the rate of change of the velocity of an  object. At the same time, the velocity is the rate of change of  the position of that same object. In other words, the velocity is the derivative of the position and the acceleration is the derivative of the velocity.
please refer this document for how to determine velocity
http://cache.freescale.com/files/sensors/doc/app_note/AN3397.pdf
can this help you?
Zhang Jun
