When flashing it stucks on starting target cpu
1,478 次查看
qinlong_liu
Excuse me ,  When I build it, it tells me that I miss some .h file. But I also stuck on almost the same point, when I try to flash it.  Could you pls support me ?
1,410 次查看
Alexis_A
Hi Liu,
Which .h file is the one that is missing? Could you take a screen shot of the error?
Alexis Andalon
