Scripting with multi link or openocd MPC55xx
pier-luc_rosa
Hi we are using MPC55xx with codewarrior and would like to know if it's possible to script the multi link adapter to flash some program. I know we can use Target Task but I need some more powerfull things... Another option is to use openOCD, but I don't know if its compatible..
stanish
there is a GUI and command line version of Pemicro flash programming utility available as a part of CodeWarrior for MPC55xx v2.x
GUI:
c:\Freescale\CW for MPC55xx and MPC56xx 2.10\pemicro\cw_progppcnexus.exe
Command Line:
c:\Freescale\CW for MPC55xx and MPC56xx 2.10\pemicro\cw_cprogppcnexus.exe
This way you can write your own script and execute it. User Guide is attached.
Hope it helps.
Stan
