Port a project from Eclipse to CW???
2,427件の閲覧回数
louishdy
I found a demo for my PowerPC using a RTOS. It uses Eclipse. Below, you can see the project.
But I have to use Codewarrior.
And I don't know how to port a project from Eclipse to CodeWarrior...
Thank you for your help.
Best regards.
Louis
タグ(1)
4 返答(返信)
2,325件の閲覧回数
TICS_Fiona
Hello Louis
Our latest CodeWarrior tools are also based on Eclipse CodeWarrior. For MCU products, please download:
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
For PowerPC processor, please download:
CodeWarrior Dev Tools for Power Architecture|NXP
What is the part number of your MCU or Processor?
Best Regards
Fiona Kuang
TIC - Technical Information Center
2,325件の閲覧回数
louishdy
Fiona,
I mean the compiler used in the project is not the one used by CodeWarrior. Is it a problem?
2,325件の閲覧回数
TICS_Fiona
Hello Louis
Please refer to this link:
https://mcuoneclipse.com/2012/05/07/exporting-and-importing-projects-in-eclipse/
If your project does not use CodeWarrior compiler and linker, I would recommend creating a new bareboard project in CW10.6.4, and then add/copy all your source files to the new project. This is the cleanest way to import a project. Below is an application note for how to do this:
http://cache.freescale.com/files/soft_dev_tools/doc/app_note/AN4727.pdf
Best Regards
Fiona Kuang
2,325件の閲覧回数
louishdy
Hello Fiona,
My PowerPC is MPC5644A
Louis
