Out of memory error CW 11.1
1,859 次查看
LuisWoll
Im getting this error message when trying to build my project:
### Error: Out of memory ###
mingw32-make: *** [Sources/engine/pwm_c.obj] Error 1 FWB_HDM_MAIN_84789_FB_3 C/C++ Problem
If i try to build a old version of the same project it builds just fine, this new version where i added some new tables is getting this error. Since I'm using CW 11.1 which does not require a license to build large projects i can't figure out what is the problem.
1 回复
1,828 次查看
ZhangJennie
Hi LuisWoll
Please let us know more information about your problem thus we can assign your issue to the related support engineer.
- your chip part number
- your demo project that can show the error
Jun Zhang
