Mpc860 debug issue
Mpc860 debug issue
3,572件の閲覧回数
ravadasrikanth3
i'm using MPC860 in my board which is not entering into debug suddenly, which is working previous.
The Transfer Error Acknowledgment(TEA) pin is toggling which is indication for BUS ERROR when trying to enter into debug.
can you help us how to solve this issue.
i checked power supply,clock,resets everything is fine.
i have another two boards with same configuration which are working,
But this board stopped working suddenly
タグ(1)
5 返答(返信)
3,466件の閲覧回数
yipingwang
If your have CodeWarrior TAP, please download and install CodeWarrior 8.8 for Power Architecture and Patch 8.8.6 from https://www.nxp.com/design/software/development-software/codewarrior-development-tools/codewarrior-n...
Patch 8.8.6 is used to install CodeWarrior TAP CCS USB driver.
Please create a bareboard project for MPC860 demo board from File->New->EPPC New Project Wizard, then try whether this project can connect to the target board successfully.
Please enable CCS log from Edit->Debug Version Settings->Remote Debug->Edit Connection->Enable logging, then connect to the target, and send the ccs log to me to do more investigation?
3,466件の閲覧回数
ravadasrikanth3
Hi yiping,
I'm doing with  the bare board project only but still it is not entering into debug.
i have another board which is working.
The only difference i observed when i'm trying to enter into debug the BUS Error pin (TEA) is toggling.
Can you just tell us what causes this pin to Toggle.
I tried all the possibilities by created new project,new code warrior usbtap,new CODE WARRIOR tool.
this board worked previously but it stopped working.
Here is the CCS log.
CCS: 0000 : ccs_open
CCS: : ipaddr = 127.0.0.1
CCS: : port = 41475
CCS: : timeout = 10
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 10
CCS: : Error message:
Connection refused
CCS: : port = 41475
CCS: : timeout = 10
CCS: : serverh = 0
CCS: : ccs_open; ccs_error = 0
CCS: 0000 : ccs_get_connection_count
CCS: : serverh = 0
CCS: : count = 1
CCS: : ccs_get_connection_count; ccs_error = 0
CCS: 0000 : ccs_available_connections
CCS: : serverh = 0
CCS: : count = 0
CCS: : ccs_available_connections; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 0
CCS: 0000 : ccs_config_cc
CCS: : serverh = 0
CCS: : config_string = utap_dpi:0
CCS: : ccs_config_cc; ccs_error = 0
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_set_timeout
CCS: : serverh = 0
CCS: : timeout = 10
CCS: : ccs_set_timeout; ccs_error = 0
CCS: 0000 : ccs_config_server
CCS: : serverh = 0
CCS: : cc = 0
CCS: : server_config = 0
CCS: : value = 4030
CCS: : ccs_config_server; ccs_error = 0
CCS: 0000 : ccs_get_config_chain
CCS: : serverh = 0
CCS: : device_list: (size = 0)
CCS: : ccs_get_config_chain; ccs_error = 0
CCS: 0000 : ccs_config_chain
CCS: : serverh = 0
CCS: : cc = 0
CCS: : device_list: (size = 1)
CCS: : device[0]:: core_type=54; device_descr=[ir_length:0;dr_bypass_length:0;bypass_instruction:0]
CCS: : ccs_config_chain; ccs_error = 0
CCS: : serverh = 0
CCS: : device[0]:: core_type=0; device_descr=[ir_length:0;dr_bypass_length:0;bypass_instruction:0]
CCS: : serverh = 0
CCS: 0000 : ccs_send_message
CCS: : coreh = [serverh:0;cc_index:0;chain_pos:0]
CCS: : message = 3
CCS: : ccs_send_message; ccs_error = 0
CCS: 0000 : ccs_stop_core
CCS: : ccs_stop_core; ccs_error = 0
CCS: 0000 : ccs_reset_to_debug
CCS: : serverh = 0
CCS: : cc = 0
CCS: : ccs_reset_to_debug; ccs_error = 0
CCS: 0000 : ccs_read_reg
CCS: : index = 2032
CCS: : count = 1
CCS: : value: (size = 1)
CCS: : 0xfff00100
CCS: : ccs_read_reg; ccs_error = 0; duration=0 ms
CCS: 0000 : ccs_write_reg
CCS: : index = 638
CCS: : count = 1
CCS: : 0xff000000
CCS: : ccs_write_reg; ccs_error = 0; duration=0 ms
CCS: : index = 638
CCS: : count = 1
CCS: : 0xff000502
CCS: : index = 638
CCS: : count = 1
CCS: : 0xff000502
CCS: 0000 : ccs_write_mem
CCS: : addr = [space:0;size:4;address:0xff000004]
CCS: : data: (size = 4)
CCS: : FFFFFF8A
CCS: : ccs_write_mem; ccs_error = 0; duration=0 ms
CCS: : addr = [space:0;size:4;address:0xff000000]
CCS: : 00600C40
CCS: : index = 2034
CCS: : count = 1
CCS: : 0x00001002
CCS: : index = 2034
CCS: : count = 1
CCS: : 0x00001002
CCS: : index = 27
CCS: : count = 1
CCS: : 0x00001002
CCS: : index = 27
CCS: : count = 1
CCS: : 0x00001002
CCS: : index = 158
CCS: : count = 1
CCS: : 0x00000007
CCS: : index = 158
CCS: : count = 1
CCS: : 0x00000007
CCS: : addr = [space:0;size:4;address:0xff000384]
CCS: : 55CCAA33
CCS: : addr = [space:0;size:4;address:0xff000284]
CCS: : 00000000
CCS: : addr = [space:0;size:4;address:0xff000100]
CCS: : FFC00001
CCS: : addr = [space:0;size:4;address:0xff000104]
CCS: : FFC000F0
CCS: : addr = [space:0;size:4;address:0xff000108]
CCS: : 00000801
CCS: : addr = [space:0;size:4;address:0xff00010c]
CCS: : FFF00010
CCS: : addr = [space:0;size:4;address:0xff000110]
CCS: : 40000801
CCS: : addr = [space:0;size:4;address:0xff000114]
CCS: : FFF00084
CCS: : ccs_write_mem; ccs_error = 0; duration=16 ms
CCS: : addr = [space:0;size:4;address:0xff000118]
CCS: : 60000801
CCS: : addr = [space:0;size:4;address:0xff00011c]
CCS: : FF0000C0
CCS: : addr = [space:0;size:4;address:0xff000120]
CCS: : 80000801
CCS: : addr = [space:0;size:4;address:0xff000124]
CCS: : F00000F4
CCS: : addr = [space:0;size:4;address:0xff000128]
CCS: : A0000401
CCS: : addr = [space:0;size:4;address:0xff00012c]
CCS: : FFF000F0
CCS: : index = 149
CCS: : count = 1
CCS: : 0x73e67c0f
CCS: : index = 149
CCS: : count = 1
CCS: : 0x73e67c0f
CCS: : index = 149
CCS: : count = 1
CCS: : 0x73e67c0f
CCS: : addr = [space:0;size:4;address:0x00002000]
CCS: : data: (size = 884)
CCS: : 4E800020 3CA0FFFF 60A5FFF1 7CA51838
CCS: : 7C651850 7C841A14 7C00286C 7C0004AC
CCS: : 7C002FAC 30A50008 3484FFF8 4080FFEC
CCS: : 4C00012C 4E800020 7C6E1B78 7C8F2378
CCS: : 7CB02B78 480000C9 4BFFFFB9 9421FFF8
CCS: : 38000000 90010000 3800FFFF 90010004
CCS: : 480000C9 3C600000 38632384 7C6803A6
CCS: : 4E800021 3CC00000 38C62374 7CC803A6
CCS: : 7DC37378 7DE47B78 7E058378 4E800021
CCS: : 3CC00000 38C62390 7CC803A6 4E800021
CCS: : 9421FFF0 7C0802A6 2C050000 90010014
CCS: : 93E1000C 7CBF2B78 93C10008 7C7E1B78
CCS: : 4182001C 7C032040 41820014 480000F1
CCS: : 7FC3F378 7FE4FB78 4BFFFF2D 80010014
CCS: : 83E1000C 83C10008 7C0803A6 38210010
CCS: : 4E800020 2C040000 4D820020 7C852378
CCS: : 38800000 480001BC 4E800020 3C200008
CCS: : 3821FFF0 3C400001 3842A4D0 3DA00002
CCS: : 39ADB800 4E800020 9421FFF0 7C0802A6
CCS: : 90010014 93E1000C 3FE00000 3BFF2304
CCS: : 809F0000 2C040000 4082001C 801F0004
CCS: : 2C000000 40820010 801F0008 2C000000
CCS: : 41820018 807F0004 80BF0008 4BFFFF35
CCS: : 3BFF000C 4BFFFFCC 3FE00000 3BFF2364
CCS: : 807F0000 2C030000 40820010 801F0004
CCS: : 2C000000 41820014 809F0004 4BFFFF59
CCS: : 3BFF0008 4BFFFFDC 80010014 83E1000C
CCS: : 7C0803A6 38210010 4E800020 7C041840
CCS: : 41800028 3884FFFF 38C3FFFF 38A50001
CCS: : 4800000C 8C040001 9C060001 34A5FFFF
CCS: : 4082FFF4 4E800020 7C842A14 7CC32A14
CCS: : 38A50001 4800000C 8C04FFFF 9C06FFFF
CCS: : 34A5FFFF 4082FFF4 4E800020 28050020
CCS: : 5487063E 38C3FFFF 41800090 7CC030F8
CCS: : 540007BF 41820014 7CA02850 3400FFFF
CCS: : 9CE60001 4082FFF8 2C070000 4182001C
CCS: : 54E4402E 54E3C00E 54E0801E 7CE42378
CCS: : 7C600378 7C870378 54A0D97F 3866FFFD
CCS: : 4182002C 90E30004 3400FFFF 90E30008
CCS: : 90E3000C 90E30010 90E30014 90E30018
CCS: : 90E3001C 94E30020 4082FFDC 54A0F77F
CCS: : 41820010 3400FFFF 94E30004 4082FFF8
CCS: : 38C30003 54A507BE 2C050000 4D820020
CCS: : 34A5FFFF 9CE60001 4082FFF8 4E800020
CCS: : 9421FFF0 7C0802A6 90010014 93E1000C
CCS: : 7C7F1B78 4BFFFF39 7FE3FB78 83E1000C
CCS: : 80010014 7C0803A6 38210010 4E800020
CCS: : 90440000 3C800000 388424B0 90830000
CCS: : 4E800020 00002000 00002000 00000374
CCS: : 00002374 00002374 00000118 0000248C
CCS: : 0000248C 00000008 00002494 00002494
CCS: : 00000008 0000249C 0000249C 00000008
CCS: : 000024A4 000024A4 0000002C 00013800
CCS: : 00013800 00000004 00000000 00000000
CCS: : 00000000 00013808 0000000C 00000000
CCS: : 00000000
CCS: : addr = [space:0;size:4;address:0x00002374]
CCS: : data: (size = 280)
CCS: : 9421FFF0 93E1000C 3BE00000 48000000
CCS: : 9421FFF0 38210010 4E800020 9421FFF0
CCS: : 7C0802A6 90010014 48000015 80010014
CCS: : 7C0803A6 38210010 4E800020 00454E44
CCS: : 3CA00001 38A53808 80050008 2C000000
CCS: : 4082001C 90650000 38000001 38600000
CCS: : 90850004 90050008 4E800020 3860FFFF
CCS: : 4E800020 2C030000 4C820020 1C03000C
CCS: : 3C600001 38633808 7C630214 38000000
CCS: : 90030000 90030004 90030008 4E800020
CCS: : 9421FFF0 7C0802A6 90010014 800D8000
CCS: : 2C00FFFE 40820020 38610008 3881000C
CCS: : 4BFFFEBD 80610008 8081000C 4BFFFF75
CCS: : 906D8000 80010014 7C0803A6 38210010
CCS: : 4E800020 9421FFF0 7C0802A6 90010014
CCS: : 806D8000 2C03FFFE 41820010 4BFFFF79
CCS: : 3800FFFE 900D8000 80010014 7C0803A6
CCS: : 38210010 4E800020
CCS: : addr = [space:0;size:4;address:0x0000248c]
CCS: : data: (size = 8)
CCS: : 00002414 00000000
CCS: : addr = [space:0;size:4;address:0x00002494]
CCS: : 00002458 00000000
CCS: : addr = [space:0;size:4;address:0x0000249c]
CCS: : 08080000 00000000
CCS: : addr = [space:0;size:4;address:0x000024a4]
CCS: : data: (size = 44)
CCS: : 00002374 00000010 0000249C 000024A4
CCS: : 000024B0 00002374 00000010 00000000
CCS: : 00000000 00000000 00000000
CCS: : addr = [space:0;size:4;address:0x00013800]
CCS: : FFFFFFFE
CCS: : index = 2032
CCS: : count = 1
CCS: : 0x00002038
CCS: : index = 2032
CCS: : count = 1
CCS: : 0x00002038
CCS: 0000 : ccs_read_mem
CCS: : 9420FFF0
CCS: : ccs_read_mem; ccs_error = 0; duration=0 ms
CCS: : 9420FFF0
CCS: : 7FE00008
CCS: : 7FE00008
CCS: : addr = [space:0;size:4;address:0x00002380]
CCS: : 48000000
CCS: : 48000000
CCS: : 7FE00008
CCS: : 7FE00008
CCS: 0000 : ccs_run_core
CCS: : ccs_run_core; ccs_error = 0
CCS: : index = 2032
CCS: : count = 1
CCS: : 0x977a5f2c
CCS: : ccs_read_reg; ccs_error = 0; duration=16 ms
CCS: : 7FE00008
CCS: : 9420FFF0
CCS: : 7FE00008
CCS: : 48000000
CCS: : index = 148
CCS: : count = 1
CCS: : 0x10000000
CCS: : index = 149
CCS: : count = 1
CCS: : 0x73e67c0f
CCS: : addr = [space:0;size:4;address:0x977a5f00]
CCS: : data: (size = 256)
CCS: : FFFF8002 F3FFFFFF FBFFFFFF FBFFFFFF
CCS: : FBFFFFFF FBFFFFFF FBFFFFFF FBFFFFFF
CCS: : FBFFFFFF FBFFFFFF FBFFFFFF F8000000
CCS: : ccs_read_mem; ccs_error = 0; duration=16 ms
CCS: : index = 285212672
CCS: : count = 1
CCS: : 0x00000002
CCS: : index = 285212673
CCS: : count = 1
CCS: : 0x00000002
CCS: : index = 285212693
CCS: : count = 1
CCS: : 0x00000001
CCS: : addr = [space:0;size:4;address:0x977a5f2c]
CCS: : FFFF0000
CCS: : serverh = 0
CCS: : count = 1
CCS: : count = 1
CCS: : 0x00000002
CCS: : index = 285212675
CCS: : count = 1
CCS: : 0x00000009
CCS: : index = 285212676
CCS: : count = 1
CCS: : 0x00000080
CCS: : index = 285212677
CCS: : count = 1
CCS: : 0x00000004
CCS: : index = 285212678
CCS: : count = 1
CCS: : 0x00000004
CCS: : index = 285212679
CCS: : count = 1
CCS: : 0x00000015
CCS: : index = 285212682
CCS: : count = 1
CCS: : 0xa0000000
CCS: : index = 285212674
CCS: : count = 1
CCS: : 0x10100000
CCS: : count = 1
CCS: : 0x00000001
CCS: : index = 285212695
CCS: : count = 1
CCS: : 0x00000002
CCS: : index = 285212696
CCS: : count = 1
CCS: : 0x00000020
CCS: : index = 285212697
CCS: : count = 1
CCS: : 0x00000004
CCS: : index = 285212698
CCS: : count = 1
CCS: : 0x00000004
CCS: : index = 285212699
CCS: : count = 1
CCS: : 0x00000017
CCS: : index = 285212702
CCS: : count = 1
CCS: : 0xe0000000
CCS: : index = 285212694
CCS: : count = 1
CCS: : 0x10200000
CCS: : index = 2000
CCS: : count = 34
CCS: : value: (size = 34)
CCS: : 0x04000000 0xfffffff0 0x00000000 0x00000000
CCS: : 0x00000000 0x00000000 0x00000000 0x00000000
CCS: : 0x00000000 0xffffb800 0x00000000 0x00000000
CCS: : 0x00000000 0x02000001 0x00000000 0x00000000
CCS: : 0x977a5f2c 0x00800404
CCS: : index = 8
CCS: : count = 2
CCS: : value: (size = 2)
CCS: : 0x977a5f2c 0x050da55b
CCS: : index = 1
CCS: : count = 1
CCS: : 0xa000007f
CCS: : addr = [space:0;size:4;address:0x977a6000]
CCS: : FFFEBFFF FFFF8002 F3FFFFFF FBFFFFFF
CCS: : addr = [space:0;size:4;address:0xffffff00]
CCS: : FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
CCS: : ccs_read_mem; ccs_error = 0; duration=15 ms
CCS: : serverh = 0
CCS: : count = 1
CCS: : serverh = 0
CCS: : count = 1
CCS: 0000 : ccs_get_messages
CCS: : message: (size = 0)
CCS: : ccs_get_messages; ccs_error = 0
CCS: 0000 : ccs_delete_cc
CCS: : serverh = 0
CCS: : count = 0
CCS: : ccs_delete_cc; ccs_error = 0
CCS: 0000 : ccs_kill_server
CCS: : serverh = 0
CCS: : ccs_kill_server; ccs_error = 0
3,466件の閲覧回数
yipingwang
I didn't find error in your CCS log.
Would you please attach CCS logs for both problem and good boards?
3,466件の閲覧回数
ravadasrikanth3
Can you just tell us what causes TEA pin to Toggle when entering into debug.
whether it maybe of address line issue or external memory access issue?
3,466件の閲覧回数
yipingwang
TEA is generated by bus monitor timer, as a result of bus timeout. By "bus timeout" I mean the following situation: the bus master initiates a transaction on the bus, but this transaction is not finished within reasonable time. "Not finished" means no transfer acknowledge asserted by bus slave. If no transfer acknowledge asserted within reasonable time, than bus timeout expires and bus monitor generated "transfer error acknowledge" (or TEA). This TEA causes machine check.
I can not say precisely, why TEA is asserted in your case, but usually the reason of TEA is an attempt to access to incorrect memory address (not assigned to any memory controller).
