MWCT1013 on WCT-15W1CFFPD
1,718件の閲覧回数
wpsigma
Hi, I am trying to use CodeWarrior USB TAP with ONCE communication. FreeMASTER does not see any device. CodeWarrior IDE version 11.1 update 1 doesn't see the device. The TAP came with no documentation or downloads. Where do I get drivers from? I also somehow managed to wipe the chip, where can I find source code to make the wireless charging work again?
1,619件の閲覧回数
xiangjun_rong
Hi, Wpsigma,
Have you solved your issue? If you can not communicate with USBTAP, have you tried to use the USB-SCI device?
XiangJun Rong
