Local labels when porting 68HC11 code to HCS12
micmed
I have some ancient 68HC11 code I am supposed to be migrating to something not end of life. I settled on the MC9S12A32CFUE and have set up an environment using CodeWarrior 5.2 with a modification to support this derivative (refer to: thread#585450).
This old code makes use of "dollar local labels" very often, and I have not been able to find an equivalent replacement that is accepted by the CW5.2 assembler. My question is, does this feature exist in the CW5.2 assembler, and if not, is there an equivalent implementation?
Example of syntax:
MAIN
    NOP
    NOP
    BRA    1$
1$
    NOP
    NOP
Thank you.
danielmartynek
