Link Error : L1102: Out of allocation space in segment PAGE_FC at address 0xFCA86C
4,489件の閲覧回数
moshao1334
I have met a problem !!!
the memory modle is large ! Here are the important files。
Original Attachment has been moved to: Project.prm.zip
Original Attachment has been moved to: Project.map.zip
タグ(1)
1,483件の閲覧回数
ZhangJennie
From the error message, there should be an object( check your source file, function or const data ) trying to be allocated at address 0xFCA86C, but the space left  in PAGE_FC ( 0xFCA86C-0xFCBFFF ) isn't enough to hold the object. So error message comes out.
Please check your source code to find out this object and allocate it to an available space.
You may use
#pragma CODE_SEG
or
#pragma CONST_SEG
if nceessary
Jennie Zhang
