I have a K60Dx256VLL10 and I would like to generate a rectangular wave (with variable frequency) on port PTB19.
To do this I tried the PE and used the PPG component. But when I try to use the "Runtime settings type: interval" I only get the following error message : "Timing setting failed in Clock configuration 0 - minimal resolution failed. Minimal applicable resolution for the selected limit is: 0.021us".
What's my problem?
Thank you
Mario
已解决! 转到解答。
Hi Mario,
I have checked the problem and it seems that there is a precision computing problem. The precision is computed from the Low limit value. Please, set the allowed error in ms (select ms in Units) and set 0.0001ms allowed error, see the following screenshot.
I have also noticed that there can be problem with the Initial Value. In case that you have trouble to set the Init. Value in us, select ms and set the same value in ms.
I use the MK60DX256VLQ10 CPU and 20.9MHz bus clock. Therefore there are different minimal value. When you click on the Advance button in the Timing dialog you can also see the clock path and you can select clock source and prescaler values directly.
Marek Neuzil
Hi Mario,
I will check with PE team to have their comments about it.
In another way can you please just confirm what is the development tool you're using.
is it CW for MCU V10.6 ?
Pascal Irrle
Hi Pascal
The CW IDE tells me:
CodeWarrior Development Studio
(c) Freescale Semiconductor, Inc. 2014. All rights reserved.
Learn more about CodeWarrior at
http://www.freescale.com/codewarrior
Installed Products:
- CodeWarrior for MCU
Version: 10.6
Build Id:140329
If you need some more information please do not hesitate to ask me...
Thank you
Mario
Hi Mario,
Marek Neuzil
