I'd like to inquire about the codewarrior.
1,858 次查看
Leekiho
I'm going to read firmware with Multilink tool for NXP-based ICMP56-based IC.
I'm going to save the data stored in the IC and upload it again.
The program is Codewarrior. I want to save it as a Hex or ef file and upload it again, so please tell me how.
1,791 次查看
Julián_AragónM
Hi @Leekiho,
Do you need to create a hex/elf file for flashing the device? If so, you can set "Create Flash Image" to generate an image file.
You can also take a look into these posts:
Julián
1,835 次查看
ZhangJennie
Hello Leekiho,
You mentioned "INXP-based ICMP56-based IC". Could you please be more specific about the part number? This information is important to find the right IDE version.
Jun Zhang
1,815 次查看
Leekiho
I'm sorry. I think I misrepresented it It is an IC component, MPC5604.
