How to simulate to read analog input (DC voltage) using Freescale CodeWarrior ver-6.3 IDE. I have used CodeWarrior ver-6.3 IDE to simulate output ports using Visualization Tool "LED Instrument". Similarly I would like to know, how we can simulate to r
srinivasubatchu
I am using Freescale CodeWarrior IDE ver6.3 to simulate I/O ports as output and to see the same in Simulator using Visualization Tool - LED Instrument. I could able to do the same for outputs with out any problem and now I want to simulate to read the switch inputs through input ports and to simulate to read analog voltage (DC voltage) through A/D converter.
Can you please help me to know the procedure to read the switch inputs, analog signals etc in CodeWarrior IDE debug window.  I do not have Freescale target board and trying with CodeWarrior IDE Simulator.
ZhangJennie
Hi Srinivasu
Please refer answer here
How to simulate to read analog input (DC voltage) using Freescale CodeWarrior Ver-6.3 IDE. I have us...
Jennie Zhang
