How to send and receive package size?
kellylim
Hi All,
I have trouble in creating a program using CAN connection. My project is for the the sender will call out for the respective receiver, then the receiver will then have to know the  size of the  message package from the sender ( may I know how to do this part?) The sender will send to receiver x number of packages it will then check sum to check if it is correct . If it is correct, it will  then complete the transmission.
Thank you.
Kelly
Hello Kelly ,
Which chip do you used ?
Alice
kellylim
Hi Alice,
I am using MC9S12XDG256MAL and MC9S12DG128 chip.
Thank you.
Kelly
Hello Kelly,
Maybe this MSCAN block guide can help you ,
especially the part of  4.2 Message Storage .
Please check the attachment .
Alice
kellylim
Hi Alice,
Thank you so much, appreciate your help.
Kelly Lim
