How to program eeprom using code warrior 5.9 tools or any others tools
pier-luc_rosa
my microcontroller is MC9S12DG128VFUE and we have code warrior 5.9. How to program the eeprom or erased it ?
ZhangJennie
Please see attached demo code.
It's for DP512 but the method is the same as DG128.
Hope this will help you,
Jun Zhang
pier-luc_rosa
Is it possible to use WL command from Code Warrior Debuguer instead. Why it doesnt persist after reboot?
ZhangJennie
Besides the demo code method, you can define a const data in EEPROM address. The const data are burned to EEPROM during download the code.
BUT, you can't revise EEPROM with debugger tool.
Hope this helps,
Jun Zhang
pier-luc_rosa
I found a tool called prog12z wich is suppose to be able to do it, not sure how it work I will give it a try.
ZhangJennie
prog12z is P&E programming tool. As I know It can program eeprom. If you have any question regarding to prog12z, please contact P&E community.
pier-luc_rosa
to connect to the device, what gnd and vdd should I use ? I am measuring 2.9V on VDD1 is it suffisiant ?
ZhangJennie
Your follow up question is no longer about CodeWarrior. Please create a thread to 16bit MCU space.
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/bd-p/16-bit
The 16bit HW engineer will help.
Jun Zhang
