How to add my plug-in in CodeWarrior?
tgc-yilmaz
I am developing software in CodeWarrior and I would like to use plug-in, that I wrote in Eclipse, in CodeWarrior. But, I do not know how to use my own plug-in in CodeWarrior. Can you help me with how to use it?
Thanks in advance...
Carlos_Mendoza
Hi tugce,
In order to install the plug-in in CodeWarrior you need to follow these steps:
  1. Start CodeWarrior.
  2. Use the menu Help > Install New Software
  3. Use the your plug-in file as local update archive: Click the 'Add...' button, then use 'Archive...' to point to the plug-in file.
  4. Select the update(s) and go through the installation process with "Next >".
  5. Restart CodeWarrior at the end of the installation process.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
