How to Program the UART port in MC9RS08 chip ?
joonsinchu
Hi all,
I'm having problem on programming the UART port for the MC9RS08KB4CWJ chip. Can anyone give me some guidance on the coding part or share me some sample code/steps to program it ?
According to the attachments below, I had assigned the Rxd and Txd in CW 10.6 but how should I assign the code in the main.c file to transmit the output data for testing purposes ?
Your sharing is much appreciated.
Thank you. Hope to hear from you guys soon.
Tags (3)
ZhangJennie
I don't have KB4 board on hand now. Please check if attached KA4 SCI demo code.
it's not exact for your chip but the method is the same.
Hope this helps!
Jennie Zhang
