FXTH870502DT1 programming
sushilnikam
Hello all,
currently Im working on the FXTH870502DT1, as Im new in this freescale platform Im facing problem while doing simple programs. I have downloaded the software stack from freescale website and trying to program it in the FXTH870502DT1, but not able to do that. Please kindly help me. If there is any document which will tell about programming and debugging steps then please share it.
sushilnikam
If you are having any working code then please kindly share it. so that I will test it on hardware
ZhangJennie
there is freescale official demo code in this url
FXTH87|Tire Pressure Monitor Sensor|Freescale
I create a new project from scratch, please try if you can well connecting with attached project.
Zhang Jun
sushilnikam
have you tested it on hardware?? I am facing problem while debugging. When it goes to the function related to the TPMS application it not able to access the TPMS internal stack which start from location 'E000' . Is it related to hardware??
sushilnikam
Probably internal firmware gets erased while programming. If you are having image of FXTH870502 then please kindly share. If you know how to make image file of internal software then please kindly share it.
sushilnikam
Hi. solve that problem. Will you please tell me the part no of the dongle which is used in the official video of TPMS.
