Communication range
Communication range
vitorgabriel100
I would like an indication of an nxp board that accepts the SMAC communication protocol and has a long communication range.
Thanks.
Tags (2)
Sebastian_Del_Rio
Hi Vitor, I hope you're doing well!
The KW41Z family of MCUs support the SMAC communication protocol and have considerable transmission power (configurable between -30 dBm to 3.5 dBm).
Tx power can change depending on external factors, such as physical obstructions, network congestion, and possible electronic interference on the same range of frequencies that you're working in. You could always improve your Tx power by adding an external PA, could you please also take a look at this Reference Design implementing it?
You can read more about this device in the KW41Z's Product Summary page, here.
Please let me know if you need more information.
Sebastian
