Codewarrior tap and script writing
tianzc
I'm using CW_VSPA_v10.3.10. After successfully debugging my code, I don't know how to deploy it to the hardware with codewarrior tap.
The board I'm using is LA1224. I tried to write a script and load into ccs but failed, so are there any examples or instructions that can tell me how to write a script?
yipingwang
There are two ways to launch LA1224/VSPA in CW,
1. Debug Configuration UI
Here you can set correct connection, then click 'Debug' to launchLA1224/VSPA
2. Debugger shell
Here you can run tcl script to launch LA1224/vspa
In folder Help/pdf there is a file "Targeting VSPA.pdf" in which the above settings are introduced in detail. Besides in folder Example there are sample projects showing the steps/settings
%3CLINGO-SUB%20id%3D%22lingo-sub-2357046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodewarrior%20tap%20and%20script%20writing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357046%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI'm%20using%20CW_VSPA_v10.3.10.%20After%20successfully%20debugging%20my%20code%2C%20I%20don't%20know%20how%20to%20deploy%20it%20to%20the%20hardware%20with%20codewarrior%20tap.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThe%20board%20I'm%20using%20is%20LA1224.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EI%20tried%20to%20write%20a%20script%20and%20load%20into%20ccs%20but%20failed%2C%20so%20are%20there%20any%20examples%20or%20instructions%20that%20can%20tell%20me%20how%20to%26nbsp%3Bwrite%20a%20script%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Codewarrior%20tap%20and%20script%20writing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EThere%20are%20two%20ways%20to%20launch%20LA1224%2FVSPA%20in%20CW%2C%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E1.%20Debug%20Configuration%20UI%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EHere%20you%20can%20set%20correct%20connection%2C%20then%20click%20'Debug'%20to%20launchLA1224%2FVSPA%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E2.%20Debugger%20shell%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EHere%20you%20can%20run%20tcl%20script%20to%20launch%20LA1224%2Fvspa%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EIn%20folder%20Help%2Fpdf%20there%20is%20a%20file%20%22Targeting%20VSPA.pdf%22%20in%20which%20the%20above%20settings%20are%20introduced%20in%20detail.%20Besides%20in%20folder%20Example%20there%20are%20sample%20projects%20showing%20the%20steps%2Fsettings%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
