Cannot find true time simulator window, need help on HCS08.
2,880件の閲覧回数
f20150335
Fresh Out Contributor
Hi, I want to design some projects with HCS08 using C in CodeWarrior. I cannot see the true time simulator and real time debugger window in my version of the software. Can you tell me how do I use it. Also it would be great if you could tell me some projects and how to get started with using the HCS08. Thanks!
4 返答(返信)
2,694件の閲覧回数
ZhangJennie
Hi Divyank.
Not all HCS08 products are supported by full chip simulation. What part number do you work with?
Jennie Zhang
2,695件の閲覧回数
f20150335
I work with the FXTH87xx00 series. I saw the register and variable values i the debug window.
2,694件の閲覧回数
f20150335
Where can I see the sensor reading values on the computer. Do i have to connect an external monitor?
2,694件の閲覧回数
ZhangJennie
Hi Divyank,
for FXTH87, CW has full chip simulation mode for it. Below screenshot is from CW11:
We can check values in viable window or memory window. see my attached video please.
Jennie Zhang
