user includes not seen by CW 10
1,426 次查看
irob
Contributor V
I'm not able to get CodeWarrior 10 to even see my user paths!  I created a new project, selected an MCU (MC9S08QG8).  Then I added a bunch of source files manually to my /Sources folder.
I hit compile and I get two C5200 errors, "*.h file not found.  These two files are in the same user folder (Sources).  I don't get it, this seems very very basic.
1,180 次查看
irob
Contributor V
Thanks, J2ME.  I read that thread, and it didn't ultimately apply.  In my case, I simply needed to move all my header files from the Sources folder into the predefined "Project_Headers" folder which CW10 creates.  Problem solved.
1,180 次查看
J2MEJediMaster
Specialist I
You might want to check out this forum thread.
---Tom
1,181 次查看
irob
Contributor V
