std::runtime_error problems
javi
I am having problems with this:
std::string error_info = "Hello";
std::runtime_error(error_info) --> this doesn't compile
but this:
std::runtime_error("Hello") --> compile ok.
Does anyone know why??
Thanks a lot and best regards,
CompilerGuru
You're syntax is defining two error_info variables.
To make it more clear, you code does the same bug as the following simple C code:
int i;
long (i);
So here is how it compiles:
std::runtime_error runtime_error_name(error_info);
PS: Which compiler did you use, and which error message did you get? For mine (CF 6.3), the error message was actually clear, I got
Error : object 'error_info' redefined
main.c line 17 std::runtime_error (error_info);
