mwcc56800e.exe gives warnings on bean generated code.
3,319 次查看
oldone1
Did I do something wrong, or is the bean generated code bad?
Do I need to turn off some warning?
Is the compiler correct, and why doesn't the IDE compile of the same file give the
same warning.
Compiling ....  ../CODE/AS1.c
### mwcc56800e.exe Compiler:
#    File: ..\CODE\AS1.c
#     172:     getReg(SCI0_SCISR);                /* Reset interrupt request fla
gs */
# Warning:                       ^
#   expression has no side effect
#     890:   getReg(SCI0_SCISR);                  /* Reset interrupt request fla
gs */
# Warning:                     ^
#     969:     getReg(SCI0_SCISR);                /* Reset interrupt request fla
gs */
# Warning:                       ^
Terry
标记 (1)
1,862 次查看
ProcessorExpert
Senior Contributor III
it seems that you are using non-default setting of compiler in your project. I have reproduced the same behavior if I switch on the "Expression has no side effect" check box in compiler setting in "C/C++ Warnings" in "Language settings" group.
Generally if you are using Processor Expert tool, the compiler setting in CW should not be changed from default values to avoid any inconvenience unless the user is sure what is he/she doing.
best regards
Vojtech Filip
Processor Expert Support Team
Message Edited by ProcessorExpert on 2009-05-26 03:32 PM
1,861 次查看
oldone1
Tried to use -w with both nounusedexpr and unusedexpr and still gets same warning.
Terry
../../bin/mwcc56800e.exe  -w unusedexpr -o obj -DBUILDPARTNUMBER=100004 -c -larg
edata -flag slld -MD -str reuse,pool -inline smart -warn on -gccincludes -i ../C
ODE -i ../include -i ../../commonInclude -i ../Sources  ../CODE/AS1.c
gs */
# Warning:                       ^
gs */
# Warning:                     ^
gs */
# Warning:                       ^
Compiling ....  ../CODE/AS1_services.c
Compiling ....  ../CODE/AS2.c
../../bin/mwcc56800e.exe  -w nounusedexpr -o obj -DBUILDPARTNUMBER=100004 -c -la
rgedata -flag slld -MD -str reuse,pool -inline smart -warn on -gccincludes -i ..
/CODE -i ../include -i ../../commonInclude -i ../Sources  ../CODE/AS2.c
#    File: ..\CODE\AS2.c
#     171:     getReg(SCI1_SCISR);                /* Reset interrupt request fla
gs */
# Warning:                       ^
#     886:   getReg(SCI1_SCISR);                  /* Reset interrupt request fla
gs */
# Warning:                     ^
#     945:     getReg(SCI1_SCISR);                /* Reset interrupt request fla
gs */
# Warning:                       ^
1,861 次查看
trytohelp
The better way will be to log it directly in the Technical support system.
Please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request. You will come to a login page.
  - You can submit your request through the web from there.
Can you please provide us your example reproducing the issue ?
Pascal
